  • 2 Vote(s) - 4.5 Average
cummins isx870 low oil pressure
hey guys ive got an 870 isx inframed about a year ago and now Im having low oil pressure.....10 psi @210 degrees at 700 rpm idle
and 30psi at 2000rpm 210degrees
what could be the cause of this?
and what can i do to up my pressure a little more?
Oil pressure sensor,oil pump,check bearings,and ecm history for any stored out of value temps,pressure etc.Send oil to anlize and cross fingers.Good luck! Regards!
Sent from my SM-G955U1 using Tapatalk
Thanks given by: timbruun
i have seen 2 cases of 870's having low oil pressure and both times it was the oil pump. One of them recently had a bearing roll and although your case had a inframe done, doesn't mean they changed the pump. Oil pressure is affected by the main bearings, cam bushings and piston cooling jets but the pump is often neglected
Was the cylinder head replaced or were new cam bushings pressed in during inframe?
Put a mechanical gauge on it and verify the pressure is actually low, ISX oil pressure sending units don't last forever.
Yes cam bushings were replace, will check with a mechanical gauge tomorrow
Sent from my HTC One using Tapatalk
Where is the sending unit located?
(05-30-2018, 07:58 AM)forcedsingularity Wrote: Was the cylinder head replaced or were new cam bushings pressed in during inframe?
(05-30-2018, 04:30 PM)ajala Wrote: Where is the sending unit located?
Located to the right of the fuel lift pump on the IFSM. 3 wire sensor, seals with an o-ring.
U mean the oil pressure sensore, change it already and same problem
If you have changed the sensor than you need to tear the engine down and find where you have your excessive wear. Start with the oil pickup tube, o ring and oil pump, then work your way up. Lower end bearings, piston cooling nozzles, and your cam bushings.
Oil pump and pickup tube o ring are the best place to start.
AA CAT
07-11-2019, 05:33 AM
07-10-2019, 05:23 AM
07-09-2019, 12:08 AM
07-06-2019, 03:57 PM
