dcm 3.7 seat ibiza 1.2 correction checksum
hi guys , please anyone control and correction checksum  of this file?.
dcm 3.7 readed and modifyed dpf egr off.
readed with protocol sangyong 2.0 tdx. with kess v2
ecu id is ok , but checksum error.
i pay if need
ibiza1.2.rar
16
808.22 KB
ibizadpfoffegroff.rar
13
808.25 KB
You are a very brave man!  Big Grin
Thanks given by: Artie
https://www.digital-kaos.co.uk/forums/sh...ess-V2-OBD
hi cawadani i read this post simply...
And do you trust blindly? The author of the post has been banned...
I repeat, you are a very brave man.... because you are playing with fire.....
i don't want play with fire, i try to understand if is possible control this file, and eventually correct cheksum, because i havent any other mode to read
(07-04-2019, 09:49 PM)Dronx81 Wrote: i don't want play with fire, i try to understand if is possible control this file, and eventually correct cheksum, because i havent any other mode to read
You are trying to write a vag ecu with a ssangyong protocol! If this is not playing with fire....
you're right, better let it go
Did you use Kess 5.017?
If I've HELPED you , hit THANKS & REP. Muscle
(07-04-2019, 08:27 PM)Dronx81 Wrote: hi guys , please anyone control and correction checksum  of this file?.
i pay if need
Your File chk repaired
FRF 2 BIN Service & TCU BIN 2 FRF MQB DQ200/DQ250/DL501/DL800/DQ500/DQ380/DQ381/AL450/AL551/AL951/AL1000/AQ450
SGO 2 BIN Service & TCU BIN 2 SGO DQ200/DQ250 Dxx/Exx/Fxx VL30/VL300
06-13-2026, 01:13 PM
