Duzaven
Location OfflineJunior Member
Thanks Given: 41
Thanks Received: 4 (4 Posts)
54
I want to figure out the procedure for unlocking the original key or programming a new one. The situation is as follows: the car owner accidentally blocked the only key. I tried using the original key and online access, but I can’t unlock it. I ordered a new key, but it still can’t be programmed because kl 15 needs to be open.
I have permission to program fbs4 keys, and the key is official.
381
Thanks Given: 922
Thanks Received: 1392 (513 Posts)
1,223
168
how you order a blank new key?
Duzaven
Thanks Given: 41
54
from an official dealer by VIN number
2,074
Thanks Given: 14473
Thanks Received: 17307 (4871 Posts)
6,433
46
If you have access and the proper rights and the vehicle is registered as all keys lost form filled out and approved, you just click continue when it insists on the key being on and keep the CAN awake by opening and closing the drivers door latch. Just click continue every time it asks for the key to be on.
______________________________________________________________________________________
2,074
Thanks Given: 14473
6,433
46
If the key is blank, you need to have all keys lost form filled out and the key can be programmed then with someone with DAS4 rights, but its best to order a key 0041 suffix after doing all keys lost form and approval.. the form is on the desktop of your Xentry tab. If you have DAS4 rights you can fill it out
Duzaven
Thanks Given: 41
54
01-16-2026, 02:35 AM
(This post was last modified: 01-17-2026, 01:06 AM by Duzaven.)
I tried different ways but an error pops up FBS4_0107.Opened a ticket in XENTRY but I can't seem to program a new key when AKL
Finally, the key is programmed
