fault code off
hi, ive tried mtx dtc remover for 3 fault codes but still coming up. brings car into limp mode. p0400,p0660 & p2075.
tia marc.....
forgot to add file
astra 07 edc16c39 stage 1.rar
37.43 KB
(06-13-2019, 07:55 PM)m4rcx Wrote: hi, ive tried mtx dtc remover for 3 fault codes but still coming up. brings car into limp mode. p0400,p0660 & p2075.
tia marc.....
forgot to add file
pass in pm +rep
astra 07 edc16c39 stage 1 dtc off.rar
35.63 KB
Muscle Press THANKS and REP+ if i HELPED.Thankyou
remap ecu files, immo, airbab files
didnt work, still the same. engine light off but in limp mode 3 dtc still showing on diagnostic.
(06-13-2019, 09:28 PM)m4rcx Wrote: didnt work, still the same. engine light off but in limp mode 3 dtc still showing on diagnostic.
clean the dtc and test
has been reset with tech2, as soon as ignition cycled the dtc are back.
BDM Readed ?
if you have BDM reading.
I have the solution for EGR and SWIRL FLAP OFF.
Tested 100%
if you still need to send PM.
04-07-2026, 09:40 PM
03-18-2026, 01:29 PM
