I am currently encountering the popular DAS multiplexer connection error. The actual fault code is:
Fault (1.2)-2.503 .9617.
Initialization of diagnosis multiplexer failed.
Possible causes:
The link between the diagnostic multiplexer and the diagnostic socket is interrupted.
The link between the diagnostic multiplexer and the diagnostic unit is interrupted.
The voltage supply at the diagnostic socket (circuit 30 and (or) circuit 31) is faulty.
i instal acronis image 12/2016 and i try with 12/2015 and its the same thing !
Possible causes:
and
