help to immo off volvo d5
hi all
any one ho can do immo off this edc16c31 ep2 fil- i like to see if car then starts.
big thanks
wiling to pay
(06-29-2019, 10:15 PM)bmw_mads Wrote: wiling to pay
Only virgin if needed
Chiptuning DynoTested
File services - DPF/EGR/DTC Exc
PCR2.1 Full Clone - Edc17 Full clone
/t.me/Edc17tricore
Thanks given by: bmw_mads
? vigin with what tool or how sir
(06-29-2019, 10:50 PM)bmw_mads Wrote: ? vigin with what tool or how sir
Read eeprom with programmer and attach here.
Virgin = automatic recode
/t.me/Edc17tricore
Ep2 and dtf fil is in abow sir
(06-30-2019, 12:07 AM)bmw_mads Wrote: Ep2 and dtf fil is in abow sir
E2p VIRGIN attached
/t.me/Edc17tricore
I finally found a Delphi tester and I see dtc 2830 lamda signal and 2530 injector 5.
So have I destroyed the ecu by open it. I was not rough at all and I turned Manny cp45 and never made a mistake. There was no sign of damage on print and I have with a measure device ohm the pins in the connector. And all legs are to find. From backside of print to connector I can find signal. Can I make this ecu or can I clone a new without open and Turing the print for bdm
Thanks for help
Io terminal with bosch sim can read and write flash and eeprom of these ecu without open.
Never open edc16c31/32, 90% of time you broken it; the best solution is a cnc machine for open a windows on bdm port.
05-23-2026, 02:04 PM
Volvo
07-20-2021, 01:21 AM
Volvo
03-18-2021, 02:59 AM
