immo VALEO 34.3 PEUGEOT 206+
Hi, can somone help me, i need good eeprom file (immoff or virgin) for V34.3 ECU PEUGEOT 206+,
my eeprom is broken when desoldering, fortunately i did a ktag read before desoldering but wrong protocol used (VALEO J34P  HWII)
 here is my dumps (map & eeprom), i think my eeprom file is corrupted (2Ko instead of 4Ko ) cause kTag road it as 95160 INSTEAD OF 95320. ANY HELP
THANKS!!
MAP 206+ Valeo V34.3.rar
0
211.1 KB
EEPROM 206+ Valeo V34.3.rar
0
837 bytes
is there somone to help?
You must remove eeprom 95320 and reprogram separately with programmer, and if you need eeprom file, i have it but no virgin and not off, readed from used ecu
Thanks given by: AKAROSSDZ
(05-29-2020, 12:36 AM)net_proo Wrote: You must remove eeprom 95320 and reprogram separately  with programmer, and if you need eeprom file,  i have it but no virgin and not off, readed from used ecu
my eeprom was dameged  by desoldering, i dont know if it will work with your original eeprom or it needs clone (eeprom+flash), if you have original eeprom file or both (+flash) send me i will try. thanks you for help Fing32
Yesterday, 06:39 PM
Peugeot
06-02-2020, 12:43 PM
Peugeot
05-30-2020, 06:39 PM
05-28-2020, 01:54 PM
