  • 41 Vote(s) - 3.07 Average
immo off peugeot 206 IAW 1AP.80
Please remove immo, dump 28F512 IAW 1AP.80
thanks in advance
IAW 1AP_80_28f512.rar
514
33.58 KB
Thanks given by: sufyan , P80GTI
hello,
Iimmobilizer is in the processor TMS 374.
There is a solution that is loaded into the program flesh.
program disables immo
Thanks given by: walker205 , WASSIM
(02-15-2014, 03:19 AM)radek222 Wrote: Please remove immo, dump 28F512 IAW 1AP.80
thanks in advance
1) replace the original 28F512, with 1AP-SWAP.quadro on about 30 seconds.
2) replace the original 28F512
1AP-SWAP.rar
1,027
1.46 KB
thank you very much
today will prove
unfortunately it did not help
I tried several times and nothing
Please for further assistance
ITALIANO
PROCEDURA DECODING ECU 1APXX
A
ENGLISH
IMPORTANT!!!!!N.B PLEASE CUT THE PIN 27. 48 IMMOBILIZER TO CONECTOR ANY ECU
PROCEDURE!!!!!!!
PROGRAMMING THE FILE MAGNETI MARELLI 1APXX CLOCK IN THE EPROM FLASH 28F512,
REMUVE THE EPROM FLASH ORIGINAL ANY ECU,INSERT THE FLASH 28F512 1APXX CLOCK
ANY ECU,TURN THE CONTACT KEY TO ON FOR 50 SECOND AFTHER TUN TO OFF,AFTHER
REMUVE THE FILE 1APXX CLOCK AND INSERT THE ORIGINAL FILE ANY ECU..
FINISH
Good luck
Thanks given by: kostagrigo
thanks in advance
solution testet and WORK
Step by step instructions for all
1. You have to desolder 28F512 chip.
2. You have to erase 28f512 and flash the clock file I attach you and power on ecu on the bench or on the car for 2 minutes, whatever you prefer.
3. You have to erase chip and flash again your original file.
4. You have to CUT 27 and 48 ECU pins.
Your car will start like a charm and never lock again, no need to remove immobox.
Press Reputation +1 = Password in PM
regards
I friends,
Can sameone help with clock file?
Ecu IAW 1AP.80
Yesterday, 06:27 PM
06-13-2026, 12:58 AM
