Hi so the batteries went flat on my key and thought it would be a good time to replace the outer casing of my key. While waiting for the new casing to arrive the key was sat without batteries for around a week. Now the IR wont open the car or anything. Will it need reprogramming or is there a procedure I can follow to resync it to the car? Any help would be greatly appreciated..
[email protected]
keyfob issue 2005 W211 E320
03-03-2017, 07:35 PM
On Autodata it says that it can only be programmed with diagnostic equipment :/
03-09-2017, 12:13 AM
So plugged the key into the ignition to try resync it and now cannot remove it from the slot. Any suggestions on how to get the ignition to release this?
03-09-2017, 08:23 AM
(03-03-2017, 07:11 PM)Sully114 Wrote: Hi so the batteries went flat on my key and thought it would be a good time to replace the outer casing of my key. While waiting for the new casing to arrive the key was sat without batteries for around a week. Now the IR wont open the car or anything. Will it need reprogramming or is there a procedure I can follow to resync it to the car? Any help would be greatly appreciated..
if car start,dont need syncro,i think pcb damage
03-09-2017, 06:41 PM
Is the shifter firmly in Park? sometimes the cable comes out of the shifter and the key won't come out of the EIS.
Thanks given by: Sully114
