ktag MPC555 problem
its 2 day I try all instruction by ktag but no way to read this ecu
I use adapter 12
12v + = pin 4 ECU
CND = pin1  ECU
thanks in advance
Just curious, did you check that the cables are all soldered in properly inside the connector socket?
For sale: Original Actia I+ME eCOM box. Comes in orig. box, manual, OBD and LAN adapter cable. PM for pricing.  All gone for now.
(02-14-2020, 08:27 AM)Mackhack Wrote: Just curious, did you check that the cables are all soldered in properly inside the connector socket?
sure
where are rest wiring,probe?
What ECU this is btw?
Reworked and updated Galletto 0475 + Kess 2.47/5.017 + Ktag 2.25/7.020 and now KESS 5.028/2.47 VR and KTAG 8.000/2.47!!!049
Thanks given by: JarsaR
(02-14-2020, 10:20 AM)Bimmeristi Wrote: where are rest wiring,probe?
in ktag help,, no resset
if you have more info please help...
Did you use  bdm adapter 14as00t01s ? If you only connect power and gnd  how it suppose to read ecu? Front connector you only need power pin 4, no gnd needed!
If I helped you, press thanks and reputation button.
(02-14-2020, 04:25 PM)SvenR1 Wrote: Did you use  bdm adapter 14as00t01s ? If you only connect power and gnd  how it suppose to read ecu? Front connector you only need power pin 4, no gnd needed!
Dear I try as ktag say
I have all adapter and all connection.
What type of ecu is this?Because i have bricked some ms45 with chinese not reworked ktag without even writing them Tongue
(02-17-2020, 07:32 PM)Stelaras Wrote: What type of ecu is this?Because i have bricked some ms45 with chinese not reworked ktag without even writing them Tongue
this is
02-25-2020, 09:08 PM
02-24-2020, 11:41 AM
02-17-2020, 04:26 PM
01-28-2020, 11:50 PM
