looking for a Incal file
look for a new Incal file for a cumins engine
esn 73565829 ecm code DT90062.09
find the update with insite  DT90062.31
but my serial number is not listed for that download
im using insite 8.3
was wonder if could update to .11 or 12
(10-10-2019, 12:00 AM)chris24 Wrote: look for a new Incal file for a cumins engine
im using insite 8.3
.txt
DT90062.12_v8.zip.txt
29 bytes
thanks for your help
but it show the same
Insite could not detect calibration for the selected ecm part number
my seial number is ecm serial number is  3080342
(10-10-2019, 02:13 AM)chris24 Wrote: thanks for your help
everything work now it was my lack of knowledge
right click and click on the option to certification codes selection, select all
the reason why i was trying update calibration is because i was getting a out of software calibration error from the turbo
cummins quickserve troubleshoot set say i must update the turbo software but first i must go in option "turbocharger actuator compatibility" and get the software and hardware number,
my problem is now because the turbo actuator was already change so i was only getting the software version for the new turbo so today i going to get the solftware number from a different truck that was never have a turbo actuator change
still having problem can some dirrect mi from here. links
look for the this file 37782561.CTT
VW
07-15-2014, 06:43 AM
VW
07-13-2014, 02:01 AM
