master II mileage corection
Hi i need corection odo master 93c66 JC  I have 251.000 and i need 283.000
Ho help
251.rar
311 bytes
org km 283120
new km 251000
forget thenx
251000 new km.rar
331 bytes
according to me the file you posted is on 283120km
when connected to the car, it shows 251,300. reading the memory NEO shows 283.120. will program the old bin and see
I write the original bin and i have 242.000. this is Jonson Controls not Sagem.
this is swap byte hoo help??
The "original" file you posted is not original, it is byte swapped and corrected improperly.
Here you have the correct file in regular format and swapped.  Write 283120 file first as 16 bit, if not work try the swap file.
I think you're having problems because of a cheap reader.
.zip
files.zip
746 bytes
DO NOT PM me asking for help with files.
Post your questions in the forum, that is what it is here for.
Thanks given by: CAR-PASS , KriyenKPp
Thanks, I advised you before writing your post. Swap Byte helped.
Yesterday, 04:21 PM
02-21-2020, 08:04 PM
02-13-2020, 09:10 PM
02-05-2020, 06:13 PM
01-24-2020, 04:43 PM
