25
Thanks Given: 336
Thanks Received: 137 (98 Posts)
319
49
12-29-2016, 08:20 PM
(This post was last modified: 12-29-2016, 08:25 PM by PedroX5.)
you have to renew NEC mcu from used key using nec programmer and after you can simply program it as new via IR.
PedroX5
PS: don´t forget to hit thanks and rep buttons !!!
26
Thanks Given: 198
Thanks Received: 87 (44 Posts)
342
69
Sorry but maybe my soft is old or something i`ve havent this option in nec programmer just test mcu and write and the mb ir can only test all keys and program only new with ir.
25
Thanks Given: 336
319
49
I used for this in past a AK500, but i have nec ir key programmer too.
I will check my old tolls and let you know
26
Thanks Given: 198
342
69
if i make bin file all FF ?
115
Thanks Given: 149
Thanks Received: 316 (107 Posts)
247
11
I think it will be right, try write eeprom FFFF, and then try write key with IR programmer...not so long.
453
Thanks Given: 444
Thanks Received: 1578 (376 Posts)
670
57
guys do you understand what are you suggesting? there is no write new eprom into key. there is a function "trick the key to get into 21DF mode to accept write over IR. It has nothing to do with writing bin file.
REP button is at your service if I helped you.
453
Thanks Given: 444
670
57
01-06-2017, 12:31 AM
(This post was last modified: 01-06-2017, 12:53 AM by efka.)
Oki mr freakit. I do not speak Bulgarian but as far as I am familiar with Slavic languages - this progger is designed for abritus made and Chinese made BE keys (most likely so called original noimmo BE made keys and BE keys made by us) not original ones. SO you get BE key and prepare and write it with this tool over infrared. Keep one thing in mind it will not prepare original .keys. Hope I explained it correctly.
My old contributions are not password protected. Get them if you need them. I will delete them in order to make space for new ones.
