need pinout nec peugeot
how do i read nec from sagem dash peugeot 307 .i have upa and original carprog
Do you have the adapter 78K0/HC912 for UPA ?
Thanks given by: BoNzO
#3
yes i have
but i dont know the pins on the adapter
Here are the dash and the adapter, hope it show clear connections for you.
File Type: .jpg
Downloaded: 29 times
File Type: .jpg
no luck.....
baudrate eror
HELLO
becarefull
the pin 11 FOR UPA is not same if you compare whit nec programmer!!!!!
pinout of nyo4 is for nec programmer!!!
look the good picture created by me!!!
[Image: mini_180914071610821149.jpg]
https://www.casimages.com/i/180914071610821149.jpg.html
#7
so i can use your picture for my upa programmer adapter?
(09-14-2018, 07:57 AM)geniehex Wrote: HELLO
becarefull
HELLO
yes this picture is for upa programmer
it is written in the top left on the picture!
your adpater it is original or clone??because some clone not work!!!you must to make technical modification
regard
Chrysler chrysler pt cruiser need cluster pinout partsaut 2 72 09-08-2018, 03:11 PM
Last Post: narkeleptk
  need pinout renault srs module 285581628r chong5195 2 59 09-04-2018, 01:43 PM
Last Post: chong5195
Misubshi i need pinout Dash Mitsubishi Space Star 2004 system101 1 48 09-03-2018, 05:39 AM
Last Post: Starling
  special NEC chip for MB ESL W204 , W212 by weixy electronics ould 4 1,223 08-29-2018, 05:15 AM
Last Post: David Sun
  Mitsubishi Canter edc16c31 pinout need fytfh 0 58 08-23-2018, 12:37 AM
Last Post: fytfh
