need sgo 4e0910156e 0060
hi all need sgo 4e0910156e 0060
(02-12-2020, 07:34 PM)partsaut Wrote: hi all need sgo 4e0910156e 0060
I can provide these 4e0910156e_0110 , 4e0910156e_0120 if you need write pm
[Image: check-evc-license-image.png]
file isn't available ony files that papi123 mention are
AFTER FLASHING 0110 GEARBOX LOST COMUNICATION
i am found it.what does it meen ?
Im not sure what those files mean, I believe they are flash files
also if you have no communication with the ecu after the flash ecu is probably damaged
no there is nr gearbox on vcds chanel 02
must flash corectly sgo
Sounds like the tcm failed if you cannot communicate with it, try hard reset but I doubt that will work. order a used replacement
