ntg 5.5 Japan > ECE conversion
Hi mate. I need help convers ntg5.5 Japan to ECE thanks
(10 hours ago)WinKarbik Wrote: Hi mate. I need help convers ntg5.5 Japan to ECE thanks
It’s not quite as simple as it sounds. I’m working through the same Japan-to-Australia conversion on my Japanese-market 2017 E400.
So far, the straightforward parts have been:
- Australian FM radio is working.
- CarPlay and Android Auto are working. The car already had the factory options for them.
- I changed the default language to English.
- I changed the fuel-consumption display from km/L to L/100 km.
- The latest EZS213 readout shows Australian market coding: 901L Australia Association, 498 Version for Japan = No and 625 Version for Australia = Yes.
- In HU55 [022] NTG Components Coding Write, I changed DSRC from installed to not installed. That cleared the ETC-card error, but finding a way to turn off the ETC warning is still eluding me.
The difficult parts are Traffic Sign Recognition and getting the navigation system fully sorted. HU55 [016] Navi Application already reports an AUSTRALIA/NZ navigation database, but I still haven’t got the navigation and regional features working as I’d like.
For Traffic Sign Recognition, I tried changing the AU country coding in SMPC213 from TSA off to TSA high CWA WWA. Monaco returned “not acknowledged”, so I can’t confirm the change was written. The hard reset completed, but that doesn’t prove the coding persisted. I’ve also seen Traffic Sign Assist High CWA in the camera variant coding, but I haven’t found a clearly labelled country or region setting there.
The HU55 job groups I’ve found that may be relevant include [005] Traffic Services, [012] Navi Tainment, [015] Telephone Application, [016] Navi Application, [017] Assistance Application, [018] Internet, [041] Remote UI Applications and [043] Driver Distraction. I haven’t identified the exact remaining settings to change. [023] Main Coding doesn’t show a country or TSA setting.
I also tried the IC213 JP High/ECE setting, but the reversing beep is still there. I actually like it; I’d just like to lower the volume.
My current suspicion is that the HU55 may need to be reflashed to remove the Japanese partition. I think that may be connected to the remaining map and Japan-specific service issues, such as Mercedes me and internet access, but I haven’t confirmed it.
You need to look at SAMIK’s software, install DTS Monaco v8, and get the right interfaces: a VXDIAG VCX SE or VX800, plus a GoDiag DoIP cable. You’ll also need a stable external power supply. I use a Victron Blue Smart IP22, I think, and my setup provides around 30 amps.
Then you need to learn how to use DTS Monaco.
After three months of tinkering, this is as far as I’ve got. If anyone can help me further, I’d be grateful too. 🙂
At the moment, I’m coming to terms with the possibility that the HU55 needs to be reflashed. 😕
Cheers,
AlanM
Cheers,
AlanM
I realize this isn’t as easy as it might seem.
I’ve worked with Monaco before; I’m currently working on a C200 (W205). The car originally came in with a suspension issue—somehow, the system for the adjustable-stiffness suspension "thought" it was supposed to have an Airmatic compressor. I found some corrupted coding and fixed it.
I also converted the fuel consumption units (from km/L to L/100 km) and adjusted the radio frequencies.
Now, I’d like to add Russian language support. I’ve done some reading on this, and if I understand correctly, the process involves flashing the system to the European version and writing a European dump to the SD card inside the HU55 head unit—but I haven’t been able to find any such dumps online.
I’d even be willing to purchase a ready-made solution for the conversion to the European specification.
