online opel sps
Hi, mates need your help, is it possible to replace a used ECM on vectra c V6 engine Bosch ME3.1.1. tell me the procedure because I bought online sps from someone I did it successfully program with the car VIN but car not start, input car pin code to ecm shows wrong security code but VIN correct, if you can help pm me with your price
(09-17-2020, 10:29 AM)gimba Wrote: Hi, mates need your help, is it possible to replace a used ECM on vectra c V6 engine Bosch ME3.1.1. tell me the procedure because I bought online sps from someone I did it successfully program with the car VIN but car not start, input car pin code to ecm shows wrong security code but VIN correct, if you can help pm me with your price
You have to reset PCM first with pin from original VIN before you change
(09-17-2020, 10:29 AM)gimba Wrote: Bonjour, les amis ont besoin de votre aide, est-il possible de remplacer un ECM utilisé sur le moteur vectra c V6 Bosch ME3.1.1. dites-moi la procédure parce que j'ai acheté des sps en ligne à quelqu'un que je l'ai fait programmer avec succès avec le VIN de la voiture mais la voiture ne démarre pas, le code PIN de la voiture dans l'ecm montre un mauvais code de sécurité mais le VIN est correct, si vous pouvez m'aider avec votre prix
Hello, there are several methods. The easiest way to unsolder the EEPROM from the original ECU and solder it in the new ECU. Use OPCOM to reset the new ECU: you need the pin code of the new and original ECU.
The bosch ME3.1.1. is a hybrid ecm I have no connection diagram and I dont know the eeprom on that particular ecm, can you send me details?
I cannot get pin that is why I opt for online sps.
Gimba, online sps flashes base software for the car. It does not touch immo part of the ecu. Who says eeprom swap has no clue about this ecu. Ignore them, no knowledge.
If you don't have ecu pin code, is as good as garbage. You would need to buy some tool to read it. Lets say from 500 euro and above. I think I have such ecu reset if you need one.
Thanks given by: acrawford
(09-26-2020, 12:34 PM)liviu2004 Wrote: Gimba, online sps flashes base software for the car. It does not touch immo part of the ecu. Who says eeprom swap has no clue about this ecu. Ignore them, no knowledge.
Thanks for your response, what tool is that can you sell for me.
Note the V6 is Z32SE which carprog or avdi does not cover.
I don’t sell tools. I’m not in selling these. I have reset ecu.
Thanks given by: gimba
(09-26-2020, 08:55 PM)liviu2004 Wrote: I don’t sell tools. I’m not in selling these. I have reset ecu.
Actually I have dozens of those ecu's, and many people come to my workshop for programming, the only means of getting pin code is service-box for euro 37 but the delay is what I dont want, more-ever you pay one at a time, no bulk payment or yearly subscription. Last week I paid for one which till now I have not receive security code, the customer is on my neck to fix his car.
Thanks given by: moxadrian
Op-Com Advanced cover this function.
I mean it can read SKC by OBD2 from this ecu Z32SE
I sent you by PM a PDF to check which special function Op-Com Advanced cover more then Professional one.
You will see that Vectra C/Signium Z32SE skc ( pin code ) can be read by OBD2
Good luck
Reverse Engineering OP-COM Rev. D+, OP-COM Rev. E+. OP-COM Professional, OP-COM Advanced, TECH2, GM MDI, Ford VCM2, Toyota Mongoose Pro2, AVDI, Multiecuscan 6-in-1 Adapter.
Thanks given by: gimba , pies , boxsport , moxadrian
05-04-2026, 07:59 PM
Opel
04-24-2026, 02:40 AM
