  • 4 Vote(s) - 4 Average
ori file request to remove revo
Does any 1 have Audi A5 2009 tfsi ori file??
8k2907115p CDNC 0005
thank you
20V 1.8T specialist...
546bhp 11.5 @ 128mph 83mm A3
516bhp 11.8 @ 123mph 81mm S3
479bhp 12.1 @ 120mph 81mm S3
New project Stroker 83mm S3
i would much prefere to restore your file to ori rather than post one, but here you are
Audi_2.0_TFSI_2008_155.2KW_8K2907115P_500889.zip
File Type: .zip
Downloaded: 7 times
maybe a free tune is not good, and a good tune is not free Kolo
Thanks given by: svvag2000
#3
(07-13-2018, 01:51 AM)ck6uk Wrote: Does any 1 have Audi A5 2009 tfsi ori file??
thank you
Drive
[Image: item2.jpg]
thank you guys will flash via obd tomorrow!
I think you need to reflash Bdm file not obd.
Revo protection is also in epprom i think.
Chiptuning - Diesel / Petrol / Stage1,2,3 /
DSG TUNING
DPF / EGR / TVA / SAI / Lambda
Crackle map ( Launch Control + No lift Shift + Antilag )
File Service
Skype - chipegrdpf
Thanks given by: psa auto
#6
Post ori from Revo, with other ori you will never start your car. Boot read and post here ... OBD will not do.
If you will flash only flash, your car will not start after few time or after 30 min, as Revo lock it also with eep, you will need to flash stock with Odis for clean and correct job.
Tuning Petrol and Diesel
CVN Fix MED17/EDC17 Vag/Bmw
Custom Tuning Stage3+ Hybrid
EFlive Deletes Tunes + HP Tuner
Skype : Act Tuning
Thanks given by: Maajkii , diagnostix
#8
(07-13-2018, 02:13 PM)psa auto Wrote: If you will flash only flash, your car will not start after few time or after 30 min, as Revo lock it also with eep, you will need to flash stock with Odis for clean and correct job.
i just seen these messages and yes it wont start
i tried checksum against the revo file but same thing
im using ktag in boot mode i have the eeprom and ori read ill upload here:
also adding ori 8K2907115P
tried to over write eeprom with immo off eeprom and it says operation not allowed on ktag...hmmm
Audi A5 Nick manual revo stage 2 decat ori read.zip
File Type: .zip
Downloaded: 15 times
Audi_A5_2.0_TFSI_2009_Turbo 8K2907115P -.zip
File Type: .zip
Downloaded: 16 times
Have some experiments with revo. I think they did protection like checksum. If you need stock you can change a few bytes on revo file and revo stages must be off. I checked on 2.0 tdi edc17c46. After changing revo dealer checked and can't activate stages, then back readed dump, stage2 activated ok. may be i was wrong but you can test if you want
VW looking for ori frf file jojo1212 2 68 Yesterday, 11:13 PM
Last Post: jojo1212
  I need ori file for Opel Zafira 2.0dti 0470504222 yanko 1 50 Yesterday, 03:01 PM
Last Post: QuantumEcu
Seat Original File Request Seat Leon PPD Marcusbs61 2 73 10-11-2018, 05:45 PM
Last Post: Korsgaard
  Need ori file Seat Leon 2.0 170cv PPD 1.2 OBD MaiiQ 7 112 10-10-2018, 02:43 PM
Last Post: MaiiQ
Seat Opel astra g ori file need Tadas117 0 50 10-10-2018, 12:39 PM
Last Post: Tadas117
