problem read eis mercedes w209 with vvdi prog
I was going to program a new key mercedes w209. I tried to read eis with vvdi prog. I did not make it. I put it back in the car. does not work. does not react. reference 2095453308.
how can I solve?
you must to read eep and flash and to check that it's they damaged. If yes, then write new, make ECU virgin and ESL virgin. Re-write keys and adapt all together.
The Best or Nothing!
Thanks given by: KriyenKPp , meysen
vvdio prog have read out eis`?you choose right eis version and processor type?
wich tool you use for add keys?
i have vvdi prog and vvdi mb tool
the model is a zgw (st12)
Tried to read with vvdi prog with adapter w209 zgw. unsuccessfully. I soldered the wires to no avail.
I can not read.
how do i sync a used one ...
pic of the eis?
Ref Mercedes
209 545 33 08
3300.2428
3300.2429
anyone with any ideas?
You soldered the coxial black and white opposite
Soldered the coxial black and white opposite
Thanks given by: fcarocha
yes, wire black.
I could read. the eprom is empty.
ezs_209.rar
66.11 KB
01-24-2020, 04:32 AM
01-19-2020, 07:52 PM
01-10-2020, 10:00 PM
01-09-2020, 02:51 PM
01-05-2020, 03:46 PM
