  • 1 Vote(s) - 5 Average
remove km from last regenerartion
I have mb 209 sprinter i wil remove last km from dpf degeneration
car has fired zo there is second hand ecu and all others cables other
modules
ecu is delphi car 213 cdi year 2013
any suggestion is welcome
rg T
(07-12-2018, 01:35 AM)TKS12 Wrote: I have mb 209 sprinter i wil remove last km from dpf degeneration
modules
rg T
I believe if you programm ''DPF Replacement'' with star diag it will be ok.
Regards
bosch yes,but delphi only with vediamo or smoke on boot mode
Do regeneration again with star diag and your Sprinter save the actual mileage for the last regeneration DPF ;-)
Guys! And with the current mileage what do we do?Big Grin
If I helped do not forget to press thanks and reputation buttonHandshake
  Last flash update version for this MED9.1 kitnoos2002 1 99 07-05-2018, 01:01 AM
Last Post: kitnoos2002
BMW BMW MSD80 remove DTC or remove NOx sensor. autoserwisbeta 5 1,502 07-03-2017, 01:32 AM
Last Post: fil1234
Infiniti 03 Infinity G35 last 6 Vin 213256 thanh1974 0 192 03-10-2017, 01:24 AM
Last Post: thanh1974
  VW T5 2.5 TDI BPC; EGR remove & Hotstart Fix; DPF Remove Medusa852 0 825 06-17-2016, 12:30 AM
Last Post: Medusa852
  TOPICSREPLIESVIEWS LAST POST I need reset immo 93C56 file for Toyota smart 2015 vga1944 0 511 01-23-2016, 09:43 PM
Last Post: vga1944
