22
Thanks Given: 687
Thanks Received: 158 (134 Posts)
1,811
705
08-04-2019, 08:21 PM
(This post was last modified: 08-06-2019, 01:13 AM by ryn079.)
good afternoon guys. i need help. a knowledgeable and good friens of mine did a dpf off for a renault captur 1.5dci i have with edc17c42. problem is that after about 2 minutes of driving, i am getting error DTC1525F3 - consistent multiplex signals for ss/cl and DTC145392 - diff. pressure sensor circuit, particle filter. pressure sensor wiring was checked and diff. pressure sensor was replaced with known good one. can someone please help me out or guide me with these errors?
i am also attaching original read of flash.
1,143
Thanks Given: 397
Thanks Received: 2238 (1070 Posts)
3,378
82
(08-04-2019, 08:21 PM)ryn079 Wrote: good afternoon guys. i need help. a knowledgeable and good friens of mine did a dpf off for a renault captur 1.5dci i have with edc17c42. problem is that after about 2 minutes of driving, i am getting error DTC1525F3 - consistent multiplex signals for ss/cl and DTC145392 - diff. pressure sensor circuit, particle filter. pressure sensor wiring was checked and diff. pressure sensor was replaced with known good one. can someone please help me out or guide me with these errors?
Your solution for Dpf OFF is not OK.
If need correct solution I can help you
Chiptuning DynoTested
File services - DPF/EGR/DTC Exc
PCR2.1 Full Clone - Edc17 Full clone
/t.me/Edc17tricore
22
Thanks Given: 687
1,811
705
08-04-2019, 11:59 PM
(This post was last modified: 08-07-2019, 04:54 PM by ryn079.)
can someone please advise about this issue i am facing?
SarMax
Location OfflineJunior Member
14
Thanks Given: 63
Thanks Received: 93 (44 Posts)
173
17
In parameters with diagnostic u must see value of diff press with car off,engine run and 2-3k rpm.Then we can talk about problem.
22
Thanks Given: 687
1,811
705
I loaded original map, even though dpf was removed physically. After a short distance, I get df1003 and df1012. 1003 referes to value of dpf pressure sensor outside tolerances and 1012 is cc/sl error due to the dpf error. Can someone please help, tell me how to emulate dpf or give me a working solution for dpf off?
22
Thanks Given: 687
1,811
705
Come on guys, no one has a solution for this captur?
293
Thanks Given: 168
Thanks Received: 721 (431 Posts)
1,069
31
edc17tricore has offered ot help you!
Chip-tuning File Service
Cars/Trucks/Agri/Construction
