257
Thanks Given: 596
Thanks Received: 1027 (543 Posts)
2,401
431
09-11-2015, 09:51 PM
Hello i have a genuine kess and k tag but i m not sattisfied with my master how can or is it even possible to change the master?
what if it is possible can i do?
if it is possible which master is relyeble and also gives me feedback of what is done now i feel like a monky loading and saving files and never seen what they have done
243
Thanks Given: 221
Thanks Received: 564 (280 Posts)
907
113
Hi
this is not possible. But what you can do is change the NXP then you have a Master you can take every Tuner. No other way.
best regards s-tune
Thanks Given: 9
Thanks Received: 37 (26 Posts)
61
0
You can ask your master to upgrade your tools to master for a fee or sell on and buy another tool that is master.
Lee
Using Genuine Master Programming Tools and Software - Kess, KTAG, MPPS, EOBD2019, Delphi E5 Passthru, Bosch KTS, Snap-On Modis Ultra, Autel MS908P, Tactrix, UltraProg2, UPA, SMOK Full, Swiftec, Autotuner, X17 + Flex, WinOLS, ECM, WinHex & Many More.
Skype: diesel.lee
Remap BHP LTD
969
Thanks Given: 1438
Thanks Received: 3192 (1559 Posts)
4,871
42
you can upgrade your unit to a master via alientech themselves
your master will likely not help you upgrade as he will then lose you as a slave
the cheapest way however to upgrade your unit to a master is to change the nxp chip on the pcb as already suggested, however this will mean youre restricted to 4.036 FW and at the end of the day its chinese cracked
good tuning is not free, free tuning is not good
i run garage but file service possible
Stage1/2 EGR DPF Adblue Swirl DTC etc
14
Thanks Given: 65
Thanks Received: 104 (48 Posts)
237
44
you should contact with local dealer of Alientech and your master. It's possible to do it
CUMMINS / CATERPILLAR / PERKINS DPF / EGR / SCR off
Agriculture DPF / EGR / Adblue
Thanks Given: 54
Thanks Received: 94 (25 Posts)
97
31
Just change the NXP fix chip to add the tokens for your kess v2 slave version
Focus on OBD Tool Since 2008
Eobdtool.com
Thanks Given: 113
Thanks Received: 30 (22 Posts)
265
17
07-05-2019, 05:30 AM
(This post was last modified: 07-05-2019, 05:54 AM by Weller.)
please explain how to change NXP to convert ktag ori slave to ori master ?
