[solved] Audi A4 2.5 EDC15VM TDI EGR OFF
Hey Guys,
i did an egr off with "DPF EGR 2016 V3.0". Could someone please verify the egr off and the Cksm. I'm not sure if it's done correctly?
So I've checked the checksum with "ecm titanium", there is a difference, right?
Specs:
Audi A4 V6 EDC15VM 2.5 TDI BDG Automatic
Vw Hardware Number: žE0907401M
Vw System Type: 2.5l V6 TDI15V15V
Vw Software Number: AG  0007
Vw Software Version: 000F57000F57
Thank you very much.
Best Regards!
.zip
EGR A4 2.5 tdi.zip
35
742.36 KB
______________________________________________
If it helped =) Thanks maybe Rep Handshake
Hey Guys,
Egr Remover worked. But do not know how. Maybe someone can explain how it works.
For example at my EDC15P the egr rate is set to maximum and then the ecu have no difference between air mass and egr.
So with vcds the set point is everytime at maximum 850 mg/H.
At the EDC 15 VM i can not see that the set point egr rate is at maximum. Only the pressure converter n18 is set all the time at 88%.
The actual egr value is always the same as airmass =)
Maybe someone can help me with a shot statement.
this will not help you, if you have dtc is only hysteresis
(07-08-2019, 10:18 PM)r4c3 Wrote: Hey Guys,
Specs:
Best Regards!
here correct egr off.
for free pass after thx and rep
AGR OFF A4.rar
41
164.46 KB
Thanks given by: makejeje , vladvia , misiek.iwaszko
06-14-2026, 10:24 PM
VW
06-11-2026, 03:31 PM
06-06-2026, 10:29 PM
