Hey everyone, hope y'all are having a good day. i'm currently having an issue with a 1999 mercedes c280. the ignition will not turn at times. first replaced key (infrared key without the blade), no luck. then we replaced the ignition lock (eis) and at first it didn't want to turn but i found a pinched wire and then it worked. and worked for me several times. so the customer came and picked it up and went to put gas in. when they went to start the car they said it didn't want to turn again. After several attempts they got the ignition to turn and start the car and drove it back here and dropped it off. I've checked all fuses and relays and they all appear to be good. i go in with the computer and go to ezs and i have 3 codes for control module. one code is B1156 which is current and 2 history codes that are B1157 - oo4 and B1157 - 005. and then i have codes
B1060: fault in can communitcation with MSS
B1023: fault in can communication with ESAR
B1022: fault in can communication with ESAL
and those three codes are current.
I proceed to do a quick scan and only other codes i have are in ME2 ASR and BAS and the fault in those are for brake light switch. To my knowledge the brake light switch wouldn't cause the ignition to not turn. so does anyone have any idea what the issue might be? maybe the k40 relay? have one coming to test it out. any help would be greatly appreciated. Thanks alot!
