gael
Location OfflineJunior Member
360
Thanks Given: 19
Thanks Received: 682 (5 Posts)
39
13
good fellow, I have a problem with a audi a3 2004 and the svdi, I connect the svdi and gives me all the info right, cs, pin code etc., gender key manufacturer to give it high in the vehicle but when encoding key I indicated no pre-coded key, no longer if it shows bad svdi the cs or tag that generates leads that bad. someone has happened.
forgive my English is not very good
Thanks Given: 244
Thanks Received: 21 (15 Posts)
172
52
U need pre-code (make dealer key) by 7 bits CS before learning.
gael
360
Thanks Given: 19
39
13
12-30-2014, 04:35 PM
(This post was last modified: 12-30-2014, 04:37 PM by gael.)
good, I pre-code key, but the car still does not recognize it, I've done the steps well but nothing tells me not pre-coded key
and I spend it with a crafter, is not whether it is the svdi or Tag
