upstream nox sensor software verification help
Replaced upstream nox sensor getting software catalyst software verification.
old sensor was throwing code that the heater element was out.
i purchased 2 sensors
1 from amazon with 2 nox sensor codes and the one currently installed from a company with 1 year warranty.
only program i have for diagnostics is jpro 2024 v1 and dla 2.0 adapter
does it need to be programmed like the Cummins one do with ista?
any tips for the backpressure valve code?
i am considering purchasing davie 4 at this point
mx13 epa 17
Run a forced regen and see if it reads the PPM for your inlet NOx. Could be a bad sensor.
