  • 2 Vote(s) - 3 Average
vag 1.2 tdi delphi dcm3.7
VW
hello
what tool is best for read and write vag 1.2 tdi with delphi dcm 3.7 ecu?
thanks!
I use CMD for it
EGR-DPF-DTC-SWIRLFLAPS-ADBLUE-LAMBDA... OFF SERVICE!
REMAPPING(TESTED) Licenced WinOls! Dyno Files!
Skype:RC-Fileservice
WhatsApp:Mail
Thanks given by: tihomir
#3
i thin only ori tools work for this ecu
If i helped please use thanks+rep buttons Smile
Kess 5.028 is able to do VAG DELPHI DCM3.7 CAN.
http://mhhauto.com/Thread-New-Russian-KESS-5-028
[Image: 180120111725515401.png]
Optimized SD Card files for any SD card CID / Activation K2.25 K2.47
read/write with pcflash many time without any problem.
And for vag dcm6.2???any clone?
Have you tested it on 5.028? I want to buy 5'028 for Vag Delphi 3.7 & Simos 12 &18.
Pcmflash is not expensive...
Modul 54 168$ + Dongle 25$ + Tactrix 189$
Thanks given by: gordonasp
#9
Super i have pcm flash with module 50 vag i must buy module 54
Thanks!!
Poslano sa mog BLA-L29 koristeći Tapatalk
  Peugeot DCM3.5 checksum help needed MKS_1 1 71 10-09-2018, 03:17 PM
Last Post: mike_service
Citroen Missing IQ or Torque limitter of DCM3.4 dbwarrior 3 176 10-08-2018, 11:27 AM
Last Post: dbwarrior
  Ford Mondeo 2.0Tdci Delphi DCM3.5 orginal jtag read need stcmotorsport 0 77 09-30-2018, 07:12 PM
Last Post: stcmotorsport
  Delphi DCM6.2 VAG CXX Engine DPF OFF Solution Wanted ! med9tfsi 3 144 09-27-2018, 09:24 PM
Last Post: jPPerformance
  S-max 2.0d 163HP DCM3.5 need tune krzysdro 3 137 09-11-2018, 11:23 PM
Last Post: CrankshaftPower
