  • 4 Vote(s) - 2.5 Average
vauxhall MJD 603.SA CLONE HELP REQUIRED PLEASE
Hi all, need advice on cloning corsa 1.3 cdti MJD 603.SA
I have second hand unit exactly the same numbers.
What would be the best way to clone, should i BDM read it, could i simply just change the eeprom from the original or could i use clone opcom .
All help much appreciated thank you..Fing32
HI use k tag read all and write all god work i have test succesfull
Thanks given by: spindle
If part number is a match all of your methods will work, easiest is BDM, as programming by reset with pin & program with Opcom you will also need to do injector codes & have both PINs.. but that does save opening them... take your pick!!
Please hit the reps & thanks buttons if this post was helpful!!!!
Except when this 6O3.SA has been reprogrammed to something else, by tech2, e.g. 6O3.S3. Then, only eeprom swap won’t work.
Another option, cloning with io terminal.
07-20-2019, 09:44 AM
VW
07-11-2019, 03:41 PM
07-10-2019, 12:04 AM
Peugeot
07-09-2019, 02:39 PM
07-08-2019, 08:36 PM
