  • 6 Vote(s) - 2.33 Average
volvo cem clone??
Hi!
Have problem with a car and need to swap cem. i got tl866II plus and the function to read intel AB28F400B5B but ewery time i hit read button i get different reading and i think they are all bad. i will post a reading below...
i also got carprog but that cant do it and also got UPA but i think that cant do it either?
any idea how to do this? thx!
If i help you i dont want cash, a thx and rep is fine Smile
I've come across this a couple times. Make sure the legs are clean and shiny, with all that goo cleaned off. Bin's no good. Also try reading it as a TB or PA.
Thanks given by: einkaa
(06-01-2018, 01:28 AM)capa_man Wrote: I've come across this a couple times. Make sure the legs are clean and shiny, with all that goo cleaned off. Bin's no good. Also try reading it as a TB or PA.
Is there any more sttings i need to do? i did uncheck the check id...
and do you maybe have virgin file for volvo v70 2004 cem?
No other changed settings, other than that. I have dumps only from S and X series cars and none virgin. I've also found it a good idea to uncheck "erase before writing" with these finicky chips, so it writes only the few bytes of changed key data.
Never tried with 866 I use different programmer gq4x4 with quality adapter...but sure function is the same. In my experience should leave check Id on. If this chip is not identified guaranteed have bad connection on legs or adapter is poor quality or wrong voltage applied to chip
It had to be WERY clean like you told me.... then it works like charm!
THX!
Glad that you got it. Smile
Thx to you!
Anyone got virgin file? im in panic here....
THX!!
I have virgin for 2004. Send me pm. Smile
The original author of Siemens Simtec 70/71, Delco HSFI-2.X and Audi Multitronic repair instructions. (Press rep if they helped you during these eight years) Smile
Volvo
11-16-2019, 01:12 AM
11-12-2019, 03:58 PM
Volvo
11-07-2019, 11:59 AM
11-06-2019, 06:16 PM
11-04-2019, 10:23 PM
