  • 3 Vote(s) - 3.67 Average
volvo s40 edc16c34 on bdm
Volvo
hi.
have a volvo s40 2010y bosch edc16c34 with motorolla sc667034mzp56
normaly in edc16c34 is mpc processor
how read that ecu with k-tag?
is it possible or what tool i will need to read it?
KTag do it without problem
(07-13-2018, 02:35 PM)MatinioIT Wrote: KTag do it without problem
but there is 4 different plug in and all for mpc if i go true volvo
if i go true protokols there shows me 2 different plug in
witch one i should pick?
X17 read on bench without opening , im sure kess is the same , just use pinout
if you go true make model engine then you have options
family 60
k tag plug in ford/psa p60
ford/psa p66
psa p118
ford p121
if you go true protokols edc16+volvo
family 68
k tag plug in volvo p68
volvo p113
witch is ok?
with ktag just select one if you dont know, you will get a message if its wrong
message like: found protocol P66
then you know the right protocol Smile
good luck
Tuning_File_Service- DPF - FAP - EGR - FLAP- Stage 1,2,3 Service
skype Denny.schip
Car, Bike, Agriculture, Bus, Truck, Marine
Maxxforce / Detroit DD15/Paccar Delphi ETC3 DPF-EGR-DEFF OFF solution
Thanks given by: boczekns
#7
Exactly, ktag will tell you what protocol to choose
thats right
thanks for your help lads
all sorted
Volvo Volvo V50 EDC16c34 DPF remove hiena 3 108 10-13-2018, 07:04 PM
Last Post: svvag2000
  Berlingo EDC16C34 immo off Grand231 5 130 10-08-2018, 03:45 PM
Last Post: Grand231
Citroen Citroen Nemo EDC16C34 immo off Grand231 14 289 10-05-2018, 10:43 PM
Last Post: Grand231
  Need original BDM File Citroen 1.6 HDi EDC16C34 WITH FAP/DPF DreamAutoInteriors 0 106 09-21-2018, 09:35 PM
Last Post: DreamAutoInteriors
  Citroen C4 1.6HDI EDC16C34 EGR DPF OFF abbassi.diag 6 375 09-14-2018, 11:28 PM
Last Post: Mirnel
