  • 11 Vote(s) - 3.45 Average
volvo v50 2.0tdi sid 803A need dpf off
i need dpf off,ecusafe and ASC too much smok. sid 803a
thank you
v50_2.rar
11
333.29 KB
(02-04-2018, 04:11 PM)Brat Wrote: i need dpf off,ecusafe and ASC too much smok. sid 803a
thank you
better check compression
Thanks given by: Brat
with ori file in idle have small smok,but with mode file asc and ecusafe to much much smok
(02-04-2018, 04:25 PM)Brat Wrote: with ori file in idle have small smok,but with mode file asc and ecusafe to much much smok
i use dpf proffesional and usaly if smoke is to much ther is problem with engine low compression
Thank you oskars268, i will check compresion.
theres always a reason for dpf to fail , injector leak ? bad turbo , bad rings , its not always the solutions thats wrong , blocked dpf is good at hiding smoke
(02-04-2018, 04:45 PM)@[email protected] Wrote: theres always a reason for dpf to fail , injector leak ? bad turbo , bad rings , its not always the solutions thats wrong
oc course battrey, but the most common problem for these engines is compression
9 hours ago
Yesterday, 05:51 PM
Audi
08-07-2020, 09:38 AM
Renult
08-06-2020, 01:29 PM
Audi
08-06-2020, 01:28 PM
