  • 18 Vote(s) - 2.39 Average
w203 C 180 (203.035) 2,0 petrol misfire problem
Hi.
I'm Looking for a manual for C 180 (203.035).
Or a help with diagnosis. i have a p201b code and not realy sure what it mean because i found a lot of different description of this error. Sometimes the engine is working good after start. but sometimes it works Rough.
When the problem occurs you tur off the engine, start and everything is ok.
P201B is DTC related to Cylinder 3 missfiring. Check everything related to such cylinder (injector, spark plug, ignition system, vaccum leackage, etc). There are a TSB from Magneti Marelli (in spanish) talking also about your issue:
http://www.magnetimarelli-checkstar.es/t...P201B-.pdf
[Image: logo_t10.png]
          Original Developer
Thanks given by: gienczes
So if I'm right. For missfiring on:
1 cylinder - P201A
2 Cylinder - P201B
3 Cylinder - P201C
4 Cylinder - P201D
I would start with swopping coil with another cylinder to see if fault transfers if no change then try same with injector if still no change/transfer of fault code to other cylinder perhaps consider hydraulic tappet/valve lifter from cold
Yes i will do It tomorrow. But want to know te dtc description because my Delphi Interface show the error and describe it as a misfire problem without the number of cylinder.
After check i will post the DTC's
