Thanks Given: 35
Thanks Received: 44 (5 Posts)
105
25
I have a 204 with esl failure I changed the motor
renewed the eis and adapted the esl the one key that came with the car to my shop is working, will the spare key also work or is there any other procedure i need to do
If i read the the eis I can see only the key number one ticked
106
Thanks Given: 713
Thanks Received: 545 (195 Posts)
437
13
If the spare key was working before just insert it and it should work.
Magpro-Flex-BitBox-Ktag-Kess-Nexiq2-AutoHex-Xentry VCI-Icom-All Vvdi
Thanks Given: 35
105
25
02-12-2017, 01:26 AM
(This post was last modified: 02-12-2017, 01:28 AM by Zain.)
yes the key was working ,the customer got only one key when he left car
the next time I get a car in with a esl failure do i have to renew the eis if I use the same esl that has has come out of the car
tool being used is vvdi
106
Thanks Given: 713
437
13
No you don't need to renew eis anymore to make esl either original or emulator. Just read eis and key password save. Then go into esl and open eis file and transfer make sure your eis and esl is connect to obd bench cable or if it's in car you need to connect kline cable that's found on vvdi obd cable.
