w205 Delphi CRD3plus
Hi guys. MB W205 2.2CDI OM651. Delphi CRD3S2 (CRD3plus.A0) ecu. 6519031746 SW. Will Kess clone work with it? It works on CRD3, CDR2 ok. And also i need tested working solution to turn ADDBLUE off on it.
post file
Tuning all cars egr dpf etc
skype-  7f98f871e5ebcec4
Depends what year, if 2016 or lower it should work
Tuning service! Stage 1-2-3, DPF OFF, EGR OFF.....
A free file will be a expensive file, it's not safe.
2015. I knew that there is tricore. So i can read/write it via boot mode also. Now is the question - who can turn off adblue correctly, and how much it will cost. welcome to PM)
Hi guys. Maybe somebody check, if the car have temperature sensor in tank of adblue ? If they have the solution for adblue off is simple. Smile
I Have tested solution to Disable Adblue in CRD3S2. Pm if interested.
05-18-2020, 12:20 AM
02-12-2020, 08:56 PM
01-22-2020, 12:38 AM
12-31-2019, 10:46 AM
