  • 14 Vote(s) - 3.86 Average
w210 / Misfire
Hello; have a w210 DAS3, m112.941 engine.
Customer came in with a CEL. We found many vacuum leaks, valve cover crankcase ventilation leaking, spark plugs fouled, 2 coils bad, blown out cats.
What we have done:
1. New catalytic converters genuine
2. Spark plugs
3. 2 Coils
4. Reseal valve cover and crankcase ventilation centrifuge
5. New rear o2 sensors
6. New air filter
7. New premium fuel
8. New fuel filter
9. All new breather/vacuum hoses
Things we checked:
1. Fuel pressure ok
2. Leakdown compression ok
3. Smoke test no leaks
4. No exhaust leaks
What the car does:
1. Idles and drives normally.
2. After 25-50 miles, the car will lose power, cough, and blow a huge cloud of smoke out the back. misfire for 5 seconds, then drives normally again.
3. CEL codes for Random Misfire, and cylinder 1 and 3 misfire.
4. rear o2 fuel trim (short term) stays at 99% all the time.
Things we are now looking into:
1. Fuel injectors
2. EGR stuck
I feel like we are throwing parts at it now.... Any suggestions?
Maybe the engine control unit is failing when getting hot.. try using a heat gun to warm it up and see if you can reproduce the fault in the shop...
Thanks given by: EASatlanta , craig coopen
(01-13-2017, 06:49 PM)Rocinante Wrote: Maybe the engine control unit is failing when getting hot.. try using a heat gun to warm it up and see if you can reproduce the fault in the shop...
Definitely a good point, what is your thought on the short term fuel trim being 99% all the time?
What do you mean by short term fuel trim? Lambda control self adaptations? Can you post a screen shot?
Also, these had lots of problems with the air mass sensor.. if the self adaptations are rich for idle and lean for part load, that's a really good sign the air mass sensor is bad..
Thanks given by: EASatlanta , Rabih AMG , craig coopen
(01-13-2017, 06:55 PM)Rocinante Wrote: What do you mean by short term fuel trim? Lambda control self adaptations? Can you post a screen shot?
Lol the customer's belt tensioner just exploded. Waiting on a new one before we can continue. 24
Ok rear o2 control was showing 99% because it isn't used on this car, was reading with a launch scanner.
Anyways, we unplugged the EGR valve, thinking it may be getting stuck.
Car running great, 100 miles hasn't malfunctioned. I will post results.
Thanks given by: Rocinante
Check spark plugs cables
MB Star2 Star3 Remote coding Anti Theft pin Map pin Renew FBS3 without special tool https://linktr.ee/SebaTechGeorgia
So, it doesn't make complete sense to me, but we unplugged vacuum to EGR solenoid, but left electrical connector. 300 miles now, no CEL, no misfire, no malfunction.
I told the customer if code comes up or symptom returns, clean EGR circuit, replace kombi valve, retest. But, all monitors are ready for emission testing. Weird.
Thank you everyone for the help!
The EGR Self test is done on deceleration on a slight decline when the engine rpm is not reducing and it activates the valve for a short period monitoring the MAP sensor. Maybe it just hasn't rechecked it yet.. Its pretty hard to get it to pass if you are driving it trying to set the monitor.. why don't you reset the ECU and see if you can get it to pass?
But a sticking EGR valve would cause the problem you were having for sure...
Thanks given by: EASatlanta , KriyenKPp
