1,884
Thanks Given: 71
Thanks Received: 4437 (720 Posts)
971
51
Start with removing all ecus from most ring, than put each after each back, than you know which is faulty, most likely it is the telephone ecu
2,095
Thanks Given: 14574
Thanks Received: 17429 (4938 Posts)
6,536
46
Or Voice control ECU or Sat radio control unit.. both are very problematic..
The wake up line should be battery voltage with the key on.. Also, was body work done on the LR of the car.. I have seen this when water gets into a control unit from bad body work or other water leak issues..
______________________________________________________________________________________
1,545
Thanks Given: 834
Thanks Received: 3312 (599 Posts)
1,500
108
01-19-2017, 09:13 AM
(This post was last modified: 01-19-2017, 09:18 AM by EASatlanta.)
Very useful to buy BMW most bus jumper to remove components and check for a break
Sent from my iPhone using Tapatalk
Number 7 in the picture
Just a squirrel trying to get a nut.
2,095
Thanks Given: 14574
6,536
46
This isn't a fiber optic problem.. its an electrical problem.. but that jumper is useful and is available from Mercedes as well
