Does anyone know how to disable DP F, diesel engine.
kindly PM.
i am encounter below problem.
P24 5328 The Input for differetial pressure sensor 1 in the diesel paticulate filter has a malfunction.the signal offset is outside the permisible range.
p24 4A7A The pressure differetial in the diesel filter (cylinder bank 1) is too low. leakage or a defetive seal was detected.
kindly PM.
