0
Thanks Given: 12
Thanks Received: 3 (1 Posts)
46
I have a 2007 s550, just updated comand software through vediamo. The reason for updating was I didnt have aux in or a sat radio option, after updating still no sat radio option under audio. I am able to see that the coding for sat radio is active under comand and MOST options in xentry, there's no fault codes in sdars, but for some reason it doesnt show up as an option on my comand at all.. any Ideas why not? I can get actual values from the unit in xentury/das just nothing in comand menu. Any help would be greatly appreciated.
ps. Any one know where I can find a nav update disc download (USA) for 2007 w221?
2,095
Thanks Given: 14574
6,536
46
I think Sat Radio is turned on by SCN coding the Comand unit, so you should be able to do it in Vediamo
58
Thanks Given: 593
Thanks Received: 501 (216 Posts)
745
133
I believe SAT radio may be an option on the early 2007s. Do you have a SAT antenna on the trunk? Did the VIDEO menu appear on the COMAND after the update?
I am not a robot. I can identify crosswalks, busses, cars, traffic lights, and mountain ranges.
13
Thanks Given: 90
Thanks Received: 98 (56 Posts)
199
25
In Xentry go to
control units,
Information and Communication
Audio Video Nav.,
under "MOST components" select command
select Retrofitting of telematic special; equipment
F3 for sat radio
follow instructions
58
Thanks Given: 593
745
133
(10-08-2016, 05:39 AM)marvelouzone Wrote: (10-07-2016, 04:15 PM)Peter6000 Wrote: In Xentry go to
control units,
Audio Video Nav.,
F3 for sat radio
follow instructions
ok, I followed your instructions.. worked for camera, as many times as I been in that section of das, never payed attention to retrofit option, but for some reason sat radio is still not showing up, I'm beginning to think something is wrong with the satellite radio module, even though, when checking it shows no faults.. it's in the scn as fitted, but still doesnt show up as an option under audio, another thing I noticed today when fiddling through actual values of sdars it said audio channel not pressent, but under composite it said present. it gets satellite signal and frequency lock when checking in das, so I'm not sure whats wrong
Do you have all modules (CGW, etc) set to the correct National Version, since SDARS is a 494 only option?
13
Thanks Given: 90
199
25
So it looks like the radio head unit does not see the sat module. But you can see it in DAS so its there and working.
Check
Command/Development data/Control unit adaption/Variant coding/NMI controls
make sure sdars installed is set to yes
Not sure her but try restarting the optical ring
its in SDAR Sattelite Ratio/Initial Startup -restart optical ring
hope this helps
if that doe not work post
