  • 8 Vote(s) - 3 Average
w251 instrument cluster
Hey there, I had to change the instrument cluster in a w251. (R 500)
It's the USA version which got imported to Germany, so I have to change it out to show kmh intead of mph.
Everything works perfectly except the mileage (only shows ---- and a warning about pre-safe not working).
I'm not interested to change the mileage, I only want it to show the original one stored in the EZS.
As I understand only virgin ICs can be married to the car.
Is it possible to virginize this IC?
Maybe someone even has an EEPROM dump?
Does it help if i change the mileage to 0 on the EEPROM?
Please enlighten me a bit, thanks! Tup
Upload the eeprom file here
Thanks given by: matze5800
upload old and new eepom we build perfekt ;-)
Thanks for your help. Well, I fucked up the board of the new one pretty bad while trying to remove the eeprom. It still works but i better not touch it again. Maybe too much heat or whatever. I just hate this stupid SMD stuff...
However i can work fine with the old one, eeprom also came off very easily. Is it possible to just switch this one to km somehow? I mean they have different part numbers, but look pretty much identical. The backlight of the display is a bit different, thats all.
BTW, is there some easier way to get to the eeprom data through the connector on the back or something?
This dump is from the old one with mph and 0 miles.
.txt
w251_old_mph.txt
40
2 KB
connect chip clip, no need to remove chip
(01-08-2017, 08:43 PM)matze5800 Wrote: Thanks for your help. Well, I fucked up the board of the new one pretty bad while trying to remove the eeprom. It still works but i better not touch it again. Maybe too much heat or whatever. I just hate this stupid SMD stuff...
1. stupid SMD stuff - it is what you have to be able to handle otherwise you must first learn soldering job. Its just a regular 8 legged eprom. hot air station works the best for that at 380 degrees Celsius but I cant teach you how to solder over the forum. https://www.youtube.com/watch?v=wB7vxEy9OSI Changing from miles to km over coding with vediamo works but you will only get 160 kmh on your dash. If you want to swap European dial to show 260 kmh you must use eprom data from euro cluster, set it on 0 km and marry it to the car.
My old contributions are not password protected. Get them if you need them. I will delete them in order to make space for new ones.
I tried, but somehow couldn't read anything unless it was soldered out. On w638 the eeprom can be accessed via k-line through the connector on the back of the cluster so I thougt that there is maybe also a solution for this one.
Thanks efka, in this video it actually looks like childs play with that hot air station. I guess its finally time to get one. I can try and fail all day long without the right tools... Do you have any good recommendations? If I understand you correctly I only need to set it to 0km and DAS lets me marry it to the car without complaining? Thats awesome! Fing32
Maybe someone has a dump of a dash with km for me? I really don't want to touch the new one again, even with a hot air gun, the damage has already been made...
you are correct on setting it to 0 and marrying it with DAS. On hot air get something digital temperature controlled. Even cheap ones will do the job. Proper temperature in soldering and desoldering is the key factor.
the eeprom must be .bin file, not .txt
