  • 6 Vote(s) - 3 Average
what is the best diagnostic tool for GM Duramax trucks
Hi All,
I am looking to buy good scantool for gm duramax trucks can you guys suggest me the good one which also do all the required functions and not to pricy a good clone will be fine for me, I am getting check engine light on my truck which making me little bit nervous.
(10-04-2016, 05:05 AM)ashu01 Wrote: Hi All,
For just codes and diagnostics I use my snap-on modis. But for just reading codes any code scanner will do. You could use a program called scan xl which can be found on here. Then for a wire use a cheap ELM327 wire or a j2435 pass thru if you have one. Or you could look on here for GM GDS 2 which is dealer level diagnostics and use a GM MDI wire which are under $500 for a clone. I also believe GM GDS 2 works with J2534 pass thru. if you want to spend $1000 you can get a AVDI which will work with GM GDS and alot of other shit. Its the best bang for you buck in terms on scan tools in my opinion. Google it and read what it can do.
Thanks given by: ashu01 , poorfireman
02-18-2020, 08:50 PM
01-26-2020, 09:21 PM
01-24-2020, 06:14 AM
01-08-2020, 05:01 PM
