  • 7 Vote(s) - 2.43 Average
wi fi
trying to connect mux to laptop sd4,in the toolkit configure mux get message due to network problems no connection to the sd connect can be established[749]
no sd connect is selected on the desired sd connect,cannot be selected
the 3 yellow lights on right bottom of screen are on.using 9/16 windows 7 hdd,connecting a mux that works on a 9/15 xp sd4.
any clues
Set up your SDConnect in toolkit /wifi/ then restart computer and in SDconnect selection select your SDConnect which you want use. There is no problem with working on both systems XP and Win 7 together.
Thanks given by: Rocinante , mrfixit
