windows10 edge disable
hello friends
as we know starfinder and wis asra work good with internet explorer but in win 10 i cant disable edge and cant start explorer so how to disable edge or there is any other browser can fix problem thanks alot
what is your default browser
Thanks given by: M.B.PKW7
(01-23-2024, 12:07 AM)Pluto Wrote: what is your default browser
internet explorer is default but edge is jump and open
did you try this
open edge , go to the right top on the 3 dots, settings, go left top settings, default browser, set it to open in IE.
In the latest compilations Internet Explorer disappeared, the old versions of starfinder work the same in compatibility mode but it uses the new version that is in the fixed threads better. WIS does not depend on any browser if you do it right, since you will not need to open ewanet every time, still, ewanet works perfectly in Edge without using compatibility mode.
WIN+R,then appear '''running windows'----input 'inetcpl.cpl'-----'advance'----not choose Enable third-party browsers
DTS9.04.016
MB software
M6+ Pro,C3
DS,Citroen,Peugeot Online
Lexus online//LatestGTS+2026 Offline/DST010
05-12-2026, 03:13 AM
05-07-2026, 05:22 AM
04-25-2026, 03:18 AM
