  • 19 Vote(s) - 2.84 Average
witech micropod 17.03.10 registration skip
hi
here is the original software to use with an original or a micropod 2 clone
chrysler, wil force us to go to the version2 of the witech en so we must buy an new micropod (1850$)
but now you can use your old one a bit longer with this simple solution
you install the program  and then you go to programfies (x86)/DCC Tools/WITECH/client  here you delete the file  app-config.xml
and you replace it withe the file included in the download
now you can start witech  it will give you registration error , just close it and go on then you can chose to go offline or use techauthority subscrition and go on agan close registration error , and everything wil work fine , and you can use it as before
it will ask to update , but DONT
if you like this treat say thanks . if you dont just say nothing , im only trying to help nothing more
im a car mechanic not a computer nerd
hope you enjoy
witech + crack https://mega.nz/file/pcZRwbwK#KlG4BPbUSg...bSJi_Zx1FY
micropod setup utility tool , can not downgrade firmware , but here it is for the interested
https://mega.nz/file/lV50iZBA#UaM0SgRP6V...ITrBl87TQE
Thanks given by: mars13 , sixcode , josebruno , Sleuth , lollo54 , baker_mu , chingon , brujostrans , chopperb , fila91 , zi0m3k , koziolek , klairc , Sergrom , Ecutuning , rdbuildr , mb-124 , Russel , tunerauto , wlemi , jabf , gcesare21 , Elektromekanico , ak993 , flopopa , ernesto125 , Matchmaker , dannygn , RiyadhFriah , gearboxny , keigoon , MOCHOLI99 , Starmobile , humber555 , Pudge49902 , joe kickass , ShufStiX , kharba , Floryn_P , antwnhszr , silver , bc131070 , pb1234 , andfonte , legendz , johnny5 , MARS1 , dvjcodec , macaruchi , marcobh5 , techauto123 , Jhonny6255 , COBRA66 , ink2000# , diagnosss , FMI , hernkey , pdt8181 , paulg1919 , serranoslv , nitodada , tsbrianesi , chipcar , mr1987negative , alex_ng , krazykar83 , Tunc Onder , Alexey_888 , avp_2005 , gtitonta , Tydean , drhg , mrrichje , chankete50 , hercaim38 , SinISbehindYOU , efrairo , vudka , JRUMMAN , billtv1 , Sam102 , asshole69 , whmen , joeeag , humberto.fo , mg_7 , cgtech , BimmerGT1 , turbo.isaac , nfsve , zalimhan74 , Damex33 , IARLLC , özi , veherion , Pedriux , felipao3010 , peter_pan , automan175 , adlr , Sergey7084 , burtons , votkarel , bounce24 , toyota , EobdRus , dcdwcd , sqlkarol , laddy , tigex , Mafioso , antonio gomez , el genio , jnp1908 , MV auto , jurlak1 , motorcareworld , tonnopazzo , moftah , raffi_hov , fezo500 , OverfuelingISX , twiganbone , Omarengr1 , wmachado1980 , rs232 , Rowland83 , V.Petroff , Scortez87 , fadifadi , kars , Dashcoder , mk-tronic , pat35 , danjot , winson , ratas , lprelectronicas , blackboxhero , taters66 , julespatch , bursuc_2005 , erciyes , Coskunusta23 , dolphin123 , @Barracuda
thanks for sharing
Does it work with Chinese micropod2?
Thanks given by: ink2000# , pat35 , erciyes
(01-31-2018, 11:06 AM)fila91 Wrote: thanks for sharing
i have tested with chines micropod ,and ik worked ok , sometimes you only have to reinstall it after a few days but im using it now 2 weeks on daily basis
oks very thanksmy firends im mexico countryFing32
does on line programming work with this solution?
(02-01-2018, 02:32 AM)koziolek Wrote: does on line programming work with this solution?
yes it does. reflashed a 2010 charger yesterday.
Thanks given by: koziolek
I have a problem with the installation ,win7pro
(02-14-2018, 12:45 AM)tomoff Wrote: I have a problem with the installation ,win7pro
i have send you an older different version in PM .let me know if it works
I, just tried instal it on win10... I have the same problem with the installation.
Run compatibility mode and it helps to install...
06-13-2026, 01:11 PM
04-27-2026, 08:52 PM
04-22-2026, 03:41 PM
