witech software question
can i use anything other adapter besides the micropod 2for the witech software thanks
(12-30-2021, 06:50 AM)jayjec Wrote: can i use anything other adapter besides the micropod 2for the witech software thanks
WiTech has J2534 programming but has to be approved by Chrysler & PC has to be registered by them I believe as I have Micropod 2 registered
Thanks given by: Alekcandr 1978 , jayjec
No.
You just can use it with the Witech 1 or Witech 2 interfaces.
As far as I know, with any other OBD interface will not start the program.
If this information helped you, don't forget to give THANKS + REP to this post
Post VIN or Year, Make, Model, Engine and Trans type for vehicles. Make, Model and Serial Number for machinery.
If you have adapter but you cannot the software.
Send teamviewer, I will active it for you. FREE!!!
Service on Cummins - Cat - Volvo Penta - Volvo Truck - FPT - Detroil - Mitsubishi - MTU - Perkins - Yanmar and Kubota
Remote installation the software, send PM for detail.
Thanks given by: jayjec
Where could I get a witech pod? And software?
(12-30-2021, 07:54 AM)singleperson Wrote: If you have adapter but you cannot the software.
ok that will work but i am looing for adapter as of right now my truck is down
what is the problem with the truck?
and what truck it is?
probably you dont need specific Witech to diagnose it, most other scanners do the same
I have the reprogram the ECM
Then you should use Chrysler J2534 software (if newer than 2010 MY)  and any J2534 adapter interface, and don't need the Micropod 2.
