  • 56 Vote(s) - 2.84 Average
works only CAN line
10
Hello
I've check cable and pins for L & K line on board - ok.
If I for sample want to connect to ABS system on cars (K line) there on instruments "ABS" lighting for a while. But not connect and break.
I can't localize the capacitor and resistor what You said.
(04-16-2013, 06:13 PM)kieper Wrote: Hello
Pin 6 on Si9241 - otput K-line -> capacitor 1nF to GND and resistor to +5V
They are very Important for K-line
Where are you search?
Thanks given by: mhh2 , kieper , ToMiBoY
12
Do not waste your time. buy another better tool, there is NO SOLUTION for that iso not working.
your tool will work only on can forever.
Believe me i have met that hardware, its really the PCB wrong manufactured, PCB . not the parts.
DO not also buy the CDP+, its worser than old vci.
The topic its nice, also on the DK its something like this, but really will end the same. no solution.
Its like you want to teach a pig to fly.
I was send back to supplier.
I'm know good some frequent defects like not working with some modules etc and can fix this. But with no k-line working I did'nt Sad
hi my friends;
the Capacitor you mentioned is positioned c701 and c703 ?? = 1nf
please look at the pcb Picture below .. tell me the pos. number
i have strange problems for cdp+ , K line works some cars such as Opel (connects all modules ENGiNE,ABS,DASH,BODY, SRS and Vw , and not Works for old BMW 1994 E36 etc..
Regards
[Image: jph4ww.jpg]
hi my friends;
Regards
Look on pictures ,I can not see where are the C701 and C703,just take multimeter and find them , of one site PIN6 on another GND , but first check your 20-PIN adapter for BMW maybe is bad quality
If all be ok with capacitor and adapter check out all relays. Coil should have between 120-180 Ohms (defaultly ~140, depending on the version of the relay) and check shorts on relay without power supply and with power supply (take 5V from usb - cut some cable - and solder black cable to "-", red to "+" on relay coil). Check one by one, there only 21 Wink relays. Once I have problem with some modules and saw that, I have only 20 relays (Chinas leave one empty place, they not soldier one relay).
hi my friends;
Regards
Hi;
For BMW E36 not connection problem, we found a strange solution !!
- we tried to connect 1994 BMW E36 with Both CDP plus (black) and old CDP pro and result no SUCCESS!
- and later We unplug the ABS ECU socket from same car , and tried again..
Suprise Borh cdp plus and also cdp Pro connected to Engine ECU !!!
and conclusion is,;
K line Works but there's a timing error or signal attenuation error..
- we have to solve it , by replacing capacitor or any other things..
all ideas will be welcome
Regards
I thing there something wrong with the car!
Do You try on another E36?
05-21-2020, 06:19 PM
02-02-2020, 07:51 PM
VW
Author: dippy
10-14-2019, 12:07 AM
08-03-2019, 11:48 PM
