  • 56 Vote(s) - 2.84 Average
works only CAN line
19
(05-11-2013, 12:40 AM)kieper Wrote: I thing there something wrong with the car!
Do You try on another E36?
Yes - there is - ABS modul.
In all cars one defect ECU can block the comunication between CDP and car
And on BMW 20 Pin adapter missing wires for Pin 17 and for Pin 7 - Service Reset - bad clone
Thanks given by: ToMiBoY
20
Hi I have same problem,
I have buy two pcs Autocom CDP+ with new design.
I have tested booth, but one have issue with connecting to cars, only I am able to connect via Generic OBD. When I open main unit I have found only different with micro relay.
1. Autocom CDP+ which have only one relay ftr-b4ga4.5z working with cars fine.
[Image: ftr-b4ga4.5zb-05.jpg]
2. Autocom CDP+ which have all relay ftr b3ga4.5z can't connect to car via OBDII, only via Generic OBD.
[Image: G16860B.jpg]
Position of different micro relay on Autocom CDP+ mainboard
[Image: photo.jpg]
Does anyone have any ideas?
(06-05-2013, 12:55 AM)autofreez Wrote: Hi I have same problem,
[Image: photo.jpg]
First check all capacitors and relays that they good soldiered (there sometimes only soldiered on one side, not both).
If all ok check all relays with my solution:
[Image: 24cxp35.jpg]
Hello.
Does someone found the solution for repair not worked k-line?
I have one tool that not work with any k-line car.
I pcb unit.
Changed relay board from working one.
Changed SI9241 for new ones.
No result.
Resistors are OK and still not works.
05-21-2020, 06:19 PM
02-02-2020, 07:51 PM
VW
Author: dippy
10-14-2019, 12:07 AM
08-03-2019, 11:48 PM
