  • 20 Vote(s) - 3.05 Average
xprog-m 5.60 communication error
Hi guys,
today I've read my SAM to post the file on the forum (see http://mhhauto.com/Thread-SAM-450-virginizing) but now xprog gives me the communication error. Can someone help me? Is the MCU corrupted or an xprog problem? Underneath the details.
Xprog 5.60 box china version
MCU 0011868V011 (Motorola HCS12)
Problem occurs on Flash and on EEPROM.
Luca
If its the same as verify error, remove all software, re install and turn internet off!
Thanks laz79,
I will try your advice. I don't know if it's the same error but it wirth a try.
Luca
Unfortunately reinstall didn't solve the problem. If I try to verify the flash the firts time I have the error attached and then Communication Error. Is the MCU corrupted? Is there a way to recover it?
Luca
.zip
Xprog Error.zip
90
128.26 KB
I got verify errors, so i reinstalled on new laptop thats not connected to the net and so far works. BUT I use 5.51.
Check and clean connections again and again
Thanks given by: smart76
Laz you were right. I solved the problem in two ways. First of all as your advice said, I noticed that when communication error occurs the software lost the com port so I checked the USB cable and made it more stable. I also attached an external power connection to the xprog box (12V/100ma external power supply) and then I've read/wrote correctly the SAM. Tomorrow I will try it on the car and see if it works.
Best wishes
Luca
(12-31-2016, 02:44 AM)smart76 Wrote: Laz you were right. I solved the problem in two ways. First of all as your advice said, I noticed that when communication error occurs the software lost the com port so I checked the USB cable and made it more stable. I also attached an external power connection to the xprog box (12V/100ma external power supply) and then I've read/wrote correctly the SAM. Tomorrow I will try it on the car and see if it works.
Best wishes
Luca
erase files atmega
