Latest news: --- Seat 2005 key type?? --- Fwgenerator v36 --- A4 EDC17C46 Microprotection read faild --- Xentry key --- CLIO II 1.2 SIEMENS sirius32N immooff with A/C --- edc16u31 PIN CODE 0281013302 --- VW EDC17.5.1 immo off plzzzzz --- DAS 2009 key gen and hardware ID tools --- LexusLS460 2011 --- C5 ECU 6LPB --- Opel Movano EDC17 VMAX --- DFP OFF?? MINI 1.6 110HP, Can check the File? --- Need key file W169 Mercedes --- A45AMG first 1,2,3 gear limiter in ECU --- Toyota C-HR mileage correction --- merceds radio code audio 10 --- Fiat 500x 9DF mileage --- Timing 1.6 BLF Engine --- liftaxle scania --- 1.8T ME7.5 Damos --- CBR 1000rr 2007r keihin 38770-Mel -F21 --- CONSULT-III v.83.11.00 --- Golf VII GTD DTC off --- Golf VII GTD DTC off --- BMW e46 n42 ME9.2 and EWS synchro --- full bdm EDC16U1 --- SDD Engineering Mode/Coded Access --- bmw etk 10.2018 --- Peugeot MEV17.4.2 Immo off Help --- cim pin code 9S12DG128 --- Cummins Calibration file --- Vw t5 vin decode --- Opel Astra H 1.6 benzin lambda cat off --- golf 7 1.6tdi edc17c64 2014 dpf need --- Corsa D pin code ---
Chokito5
(Junior Member)
Registration Date: 05-01-2011
Date of Birth: Hidden
Local Time: 10-19-2018 at 09:27 AM
Status: Offline
Chokito5's Forum Info
Last Visit: 10-15-2018, 02:44 PM
Total Posts: 24 (0.01 posts per day | 0 percent of total posts)
Total Threads: 1 (0 threads per day | 0 percent of total threads)
Time Spent Online: 1 Day, 4 Hours, 22 Minutes
Referred By: N/A
Members Referred: 0
Reputation: 0 [Details]
Comments 0 (0 sent | 0 received)
Buddy List (Total 0)
Chokito5 hasn't made any friends yet.
Last Visitors
Not visited yet.
Chokito5's Contact Details
Private Message: Send Chokito5 a private message.
Additional Info About Chokito5
Sex: Male
Comments (Total )
