Latest news: --- Fwgenerator v36 --- A4 EDC17C46 Microprotection read faild --- Xentry key --- CLIO II 1.2 SIEMENS sirius32N immooff with A/C --- edc16u31 PIN CODE 0281013302 --- VW EDC17.5.1 immo off plzzzzz --- DAS 2009 key gen and hardware ID tools --- LexusLS460 2011 --- C5 ECU 6LPB --- Opel Movano EDC17 VMAX --- DFP OFF?? MINI 1.6 110HP, Can check the File? --- Need key file W169 Mercedes --- A45AMG first 1,2,3 gear limiter in ECU --- Toyota C-HR mileage correction --- merceds radio code audio 10 --- Fiat 500x 9DF mileage --- Timing 1.6 BLF Engine --- liftaxle scania --- 1.8T ME7.5 Damos --- CBR 1000rr 2007r keihin 38770-Mel -F21 --- CONSULT-III v.83.11.00 --- Golf VII GTD DTC off --- Golf VII GTD DTC off --- BMW e46 n42 ME9.2 and EWS synchro --- full bdm EDC16U1 --- SDD Engineering Mode/Coded Access --- bmw etk 10.2018 --- Peugeot MEV17.4.2 Immo off Help --- cim pin code 9S12DG128 --- Cummins Calibration file --- Vw t5 vin decode --- Opel Astra H 1.6 benzin lambda cat off --- golf 7 1.6tdi edc17c64 2014 dpf need --- Corsa D pin code --- does anyone do remote bmw programming ---
codewarior273
(Junior Member)
Registration Date: 03-14-2011
Date of Birth: 01-01-1980 (38 years old)
Local Time: 10-19-2018 at 08:38 PM
Status: Offline
codewarior273's Forum Info
Last Visit: 3 hours ago
Total Posts: 106 (0.04 posts per day | 0.01 percent of total posts)
Total Threads: 21 (0.01 threads per day | 0.01 percent of total threads)
Time Spent Online: 4 Days, 18 Hours, 29 Minutes
Referred By: N/A
Members Referred: 0
Reputation: 2 [Details]
Comments 0 (0 sent | 0 received)
Buddy List (Total 0)
codewarior273 hasn't made any friends yet.
Last Visitors
ecu-tech (10-01-2018 - 10:11 PM)
codewarior273's Contact Details
Email: Send codewarior273 an email.
Private Message: Send codewarior273 a private message.
Comments (Total )
