Latest news: --- chevrolet matiz 2007 add key into bin file --- Need Pin from ECU (EDC15C2) PSA --- Nissan JUKE crash clear --- Volvo obd cabe with kess eu clone --- looking for VW ori files. --- ORIGINAL FILE TEST --- passat b6 CAN gateway upgrade help --- Lookin for bdm frame and bdm adapers --- ford sim210 edc16 sync data --- alfa 156 ecu --- bmw x5 petrol need dtc off --- ABS coding VW Tiguan --- hyundai 95910-a0050 creta --- BMW M240i MG1 OPF Problem --- SRS G463 --- abs coding --- NEED HELP IMMO OFF VECTRA C TRIONIC 8 --- toyota ractiz 2012 model engine 1NR-FE ECU software no. 89663-52P04 file needed --- Updgrading to SD Connect C4 or C5? --- pegeout 3008 start/stop off --- DTC OFF - Sagem s3000 --- Need to update injector code. --- "userlink" software --- 5WK9 0322 index 10 immo off --- Close tread! --- w211 me2.8 95p08 and ezs 3k91d help --- Ford Radio V Code Full List 000001 to 999999 --- Wiring diagram VW Transporter T5 2010 --- Password calculation W210 --- Please help need ORI File for Camaro SS 6.2L V8 , Bj.2009 , 453PS GM12633238 --- Skoda roomster --- SsangYong library --- Keycode Citroen --- Seat Exeo 1.8 T 150 CV ME 7.5 stage 1 need --- clear dump airbag nissan pathfinder ---
gu5t3r
(Junior Member)
Registration Date: 02-01-2011
Date of Birth: Not Specified
Local Time: 10-16-2018 at 06:49 PM
Status: Offline
gu5t3r's Forum Info
Last Visit: 08-01-2018, 03:35 PM
Total Posts: 9 (0 posts per day | 0 percent of total posts)
Total Threads: 0 (0 threads per day | 0 percent of total threads)
Time Spent Online: 4 Hours, 13 Minutes, 29 Seconds
Referred By: N/A
Members Referred: 0
Reputation: 0 [Details]
Comments 0 (0 sent | 0 received)
Buddy List (Total 0)
gu5t3r hasn't made any friends yet.
Last Visitors
Not visited yet.
gu5t3r's Contact Details
Email: Send gu5t3r an email.
Comments (Total )
